Activity Forums Adobe After Effects Expressions Using Slider to control several puppet points on different layers
  • Kalleheikki Kannisto
    February 4, 2016 at 3:17 pm
    It should be simple: You would use an expression that adds the value of your multiple-finger control to the individual control. If you know how to do it with one slider, all you need is a “+” and the expression for the second slider.
