Activity › Forums › Adobe After Effects Expressions › Using slider expression to control oscillating value of opacity?
  • Using slider expression to control oscillating value of opacity?
    Posted by Germain Wu on June 28, 2011 at 10:29 am
    Hi!
    I’m attempting to use a expression control slider to control the frequency of a layer’s visibility but have no idea how to.
    I’ve been doing it manually but it’s a pain when I need to change the keyframes so I was wondering how I can do it with expression.
    I have a layer that turns on and off from say twice per second to the maximum keyframe I can have in the comp’s framerate usually sync to the music.
    I have done it by spacing keyframes but is there a method to do it using slider control so the frequency of switching on and off can be animated using just 2 key frames?
    Greg Burrus replied 15 years, 3 months ago 2 Members · 1 Reply
  • Greg Burrus
    June 28, 2011 at 1:23 pm
    There is actually a preset already set up to do pretty much this in a random way.
    If you look in animation presets > behaviors > Opacity flash random or just search opacity flash you will find it.
    You can use this a building block to make exactly what you need or just use as is.
    Hope this helps.
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
