Activity Forums Adobe After Effects Using Shatter and Making the Shattered parts fall straight down.
  • Using Shatter and Making the Shattered parts fall straight down.
    Posted by Adele Carboni on June 8, 2005 at 10:22 pm
    Hi, I’ve been trying to get shatter to make the pieces fall straight down.
    All my attempts made the pieces go down have not worked. I assumed gravity would be but it wasn’t or I did something wrong. Thanks for any help.
    Also, it seems when you save a preset in shatter it also saves the the item you were shattering position data. Which if correct makes saving a shatter preset somewhat less then useful.
    Thanks again. Adele
    Adele Carboni replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
