Activity › Forums › Adobe After Effects › Using Shadows
  • Using Shadows
    Posted by Yossi Siegel on January 11, 2009 at 6:54 am
    Sorry if this is a repeat, since I already posted this and it didn’t seem to have worked, so…
    In any case, I was wondering how to add a shadow to a footage, of an object that is not visible on screen.
    So, for example, those shots you see in the movies where the shadow of a gigantic spaceship–or something slowly blocking the sun or something–looming over the land from above.
    Yossi Siegel replied 17 years, 8 months ago 2 Members · 2 Replies
  • David Bogie
    January 11, 2009 at 4:44 pm
    Two simple processes.
    1. Simple 2d: Create the shape of your shadow and simply use it as a layer. Fill it with gray, add some blur, various transfer modes or transparency settings till you get what you consider satisfactory illusion.
    2. Simple 3D: Build the shape and place it off the edge of the camera’s view. Add a light that projects the shadow the direction and intensity that suits yoru needs. If you seen is build as a 3D layers, the shadw cast by the object will interact with them beautifully.
    bogiesan
  • Yossi Siegel
    January 18, 2009 at 4:45 am
    “If you seen is build as a 3D layers, the shadw cast by the object will interact with them beautifully”
    What do you mean?
