Activity Forums Audio Using Sennheiser ew g3 100 Wireless Lav system abroad
  • Using Sennheiser ew g3 100 Wireless Lav system abroad
    Posted by Joe Bressler on January 4, 2017 at 6:26 pm
    Hello,
    I have a shoot happening this month which is taking me to London, Seoul, and Zurich from the USA. I was wondering if someone can advise as to whether or not I can use my block A Sennheiser ew g3 100 tx and rx in these countries. I know that different countries have different frequencies that they use for various applications, but I’m wondering if I scan using easy set up with my Block A set if there is a chance I will not find ANY clear frequencies?
    I would perform a search with Sennheiser’s frequency finder but South Korea and Switzerland are unavailable. Additionally finding sound gear rental in South Korea is proving challenging.
    Peter Groom replied 9 years, 8 months ago 3 Members · 2 Replies
  • Eric Toline
    January 5, 2017 at 2:28 am
    You should be fine in the countries you named. The chances of being blocked out of open frequencys are minimal. Just to be safe see if you can rent a 470 block of G3 wireless as a backup.
    \”I push the RECORD button and hope for the best\”
  • Peter Groom
    January 6, 2017 at 3:12 pm
    Hi
    UK is ch 38 (606-614MHz.) These frequencies are licensed for use too ie, if you use a radio mic in the uk without a license, it will likely work, but if a licensed user has issues , then your equipment can be confiscated. Use outside major cities is unlikely to have problems, but in London and other big cities, the use is very high, so Id get a license @£70 UKP.
    Peter
    Post Production Dubbing Mixer
