Activity Forums Adobe Premiere Pro using screen mode in duplicate layer to fix underexposed footage
  • using screen mode in duplicate layer to fix underexposed footage
    Posted by Jim Bachalo on August 25, 2011 at 6:12 pm
    Hi
    Can anyone tell me if using screen mode in duplicate layer (either in PPro or AE) is a preferred method to fix underexposed footage?
    My understanding is that this method won’t reveal more noise, which is what happens when you simply lighten the shadow areas using a levels or curves adjustment.
    Local is the new global
    Jon Barrie replied 15 years ago 2 Members · 3 Replies
  • Jon Barrie
    August 25, 2011 at 11:29 pm
    Instead of duplicating an instance if a clip and having to group them for editing, transitions require workflow differences there an effect called “solid composite” that can apply this look and stay as a single clip. It is is PPro and AE.
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Jim Bachalo
    August 26, 2011 at 1:17 am
    Are you sure you don’t mean the calculations effect?
  • Jon Barrie
    August 26, 2011 at 2:00 am
    Calculations effect wad the old one. But yeah that would work too.
    Be aware that if you scale te clip the composite won’t adjust with it.
    You would need to nest it and scale the nest.
    – JB
    Jon Barrie
    aJBprods
