Activity Forums Adobe Premiere Pro using ‘scale to frame size’ will it effect the quality on the final export?
  • using ‘scale to frame size’ will it effect the quality on the final export?
    Posted by Tino D’voe on January 31, 2013 at 9:17 pm
    Can someone please clarify this info? I’ve read different opinions online on how this effects footage with premiere cs6. From what I understand so far, the auto scale function not only makes your video fit the working timeline, it also removes information. Leaving you with inferior quality on your final output.
    Is this true or false? I’ve shot a video using various setting with my red camera from 5KHD down to 2KHD. my project is a 1080p timeline. Is it fine for me to use the auto scale setting or should i drop all the files in and manually shrink them down to size?
    Thanks for the help!
    Chris Caulder replied 13 years, 6 months ago 6 Members · 5 Replies
  • Walter Soyka
    January 31, 2013 at 9:32 pm
    Premiere’s Scale to Frame Size option seems to work before the Motion tab, and is not concatenated with any tranforms in the Motion tab.
    Let’s take a practical example: RED 4k footage at 4096×2304. When you place that in a 1920×1080 and check Scale to Frame Size, Premiere scales the footage down to 1920×1080, and then makes that the new 100% in the Motion tab. If you wanted to blow-up or push into the frame, adjusting the Motion tab to say 150% would scale that new 1920×1080 frame up, rather than scaling the original 4096×2304 frame down a bit less than it had before.
    My advice is to use Scale to Frame Size for all the shots you don’t care to repo, but to turn it off and manually scale the shots you do want to repo.
    Walter Soyka
  • Bernhard G.
    February 1, 2013 at 9:23 am
    Hello,
    I absolutely agree applying the ‘Fit so Sequence’ function on all clips;
    it could also be turned to default in the preferences.
    I would find it helpful, if this was standard, but I would also appreciate
    if there was an additional fix assigned category (beside Motion, Opacity, Retime)
    in the Effect Controls window, labeled ‘Standards Conform’ or ‘Clip Format’.
    Therein I would like to see options for Fit to Sequence, De-Interlacing, Frame-Blending, Color Space, etc.; everything with better control and more professional options like motion analysis;
    simply everything about the behavior of a clip to match the sequence.
    Wrote this feature request to Adobe. Now hoping for CS7…
    Best regards,
    Bernhard
  • Kevin Monahan
    February 1, 2013 at 7:43 pm
    Thanks for the FR Bernhard.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Dean Anderson
    February 5, 2013 at 5:55 pm
    We record our footage in 1080i and constantly need to send two different types of output to TV stations, we send a 1080i version and an NTSC (720×480)version. We have been using After Effects to do the down-converting and it looks pretty good, but I recently came across this post from Todd Kopriva that says that it is better to do it in PP. https://forums.creativecow.net/readpost/2/1008025
    I tried to do it in PP, but it looks horrible. I have a quadro 5000 card and have it set to use CUDA acceleration.
    My question is, what method should I use to get the best results in PP from scaling and exporting. I used the Motion>Scaling effect and scaled it down to 34%, but I have also heard that I should use “Scale to Frame size” Does anyone know the correct method? Even with “Maximum Render Quality” it still looks bad. After Effects seems to do a much better job.
    Thanks for the input.
    Dean Anderson
  • Chris Caulder
    February 19, 2013 at 9:15 pm
    Ok, I’m just starting out with Premiere, but I’ve found that it does NOT affect the final export–
    I use proxies since my computer is so slow. The proxies I make are LOW res (180)… and when I import them onto my 1080p timeline (24p DSLR)… they are tiny. I right-click each clip, “Scale to Frame Size” and they fill up my preview window, as expected.
    Upon final export – I “replace footage” with all my original HD files… and the final MP4 (for YouTube) looks exactly like what I edited.
    Took me a little while to figure that out… but, it’s simple. Hopefully that helps!
