Activity Forums Storage & Archiving using same HDD to export file in Premiere Pro
  • using same HDD to export file in Premiere Pro
    Posted by Kiki Muchtar on November 7, 2016 at 7:03 am
    We use Premiere Pro to edit ProRes422HQ files. The final output are 2 kinds: H.264 (SD size) and ProRes 422 (2K size).
    Right now we are using 3 HDD: 1-where the OS is installed, 2-where the ProRes422HQ saved, and 3-where we save the output. My question: is it necessary to separate the HDD where the working files are saved and the HDD where the exported files are saved? We use the 3 HDDs to avoid file corruption. But if this is not true, we can use the 3rd HDD for something else.
    Cheers,
    Kiki
    Kiki Muchtar replied 9 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
