Activity Forums DaVinci Resolve Using Resolve to batch export
  • Using Resolve to batch export
    Posted by David Mathis on September 6, 2014 at 2:51 am
    Is it possible to send an XML out from FCP X into Resolve and batch export clips in the H.624 codec for client review?
    Glenn Sakatch replied 12 years ago 2 Members · 1 Reply
  • Glenn Sakatch
    September 6, 2014 at 3:22 pm
    you can certainly set up different timelines within a project, or even across different projects, and tell resolve to batch export those. Its not listed as a specific function in the box. In your delivery page, on the lower right corner where your start output button is, you can right click and it will show you all sequences across all projects waiting to be output.
    If it is individual clips you want to do, just set up a timeline with all those clips, and create a quicktime output setting that makes individual outputs instead of 1 big clip.
    Glenn
