Activity Forums Boris FX Using RED in FCP
  • Using RED in FCP
    Posted by Delano Bryant on November 2, 2008 at 5:14 pm
    I want to use RED in FCP. WHat is the best work-around? And I need a settings for RED to workin in FCP HD.
    thanks
    Attitude – It takes 43 muscles to
    frown and 17 to smile, but only
    three for proper trigger squeeze!
    (_E=mc2_)
    Peter Mcauley replied 17 years, 10 months ago 2 Members · 3 Replies
  • Peter Mcauley
    November 3, 2008 at 2:25 pm
    Hi Delano,
    RED behaves as a filter when used in FCP so you simply drag it from the filters group and drop it directly onto a clip in the FCP timeline. Then, you should double click the clip with the filter and you will see that the RED banner will appear in the Controls Window. Click on the banner and the RED interface will appear. Create the effect that you want and then click on the apply button to return to the FCP interface.
    RED is resolution independent – and when used on a clip in FCP, the clip determines the resolution. To create an HD effect, apply RED to an HD size clip.
    There are many free tutorials here: https://www.borisfx.com/tutorials/#null
    Cheers,
    Peter.
  • Peter Mcauley
    November 3, 2008 at 9:36 pm
    There are also training DVD’s, which can be purchased fro our web site that might help.
    Cheers,
    Peter.
  • Delano Bryant
    November 3, 2008 at 9:44 pm
    Thank you so much. I’ve tried some of the tutorials on boris and they aren’t too user friendly.
    But thanks.
    (_E=mc2_)
