Activity Forums DaVinci Resolve Using RD3 Files in Resolve Lite
  • Using RD3 Files in Resolve Lite
    Posted by Andy Matthias on May 23, 2012 at 7:34 pm
    I downloaded and installed Resolve Lite and I wanted to try experimenting with grading some RD3 files. I added their location to the media library and set everything up in the BROWSE and CONFORM rooms. When I go to the COLOR room I can’t see any of the clips and I get that error about running GPU algorithms. After doing some searching online I found a RED workflow manual and it mentions something about setting the source to the RED Decoder. I can’t find that anywhere in the SETUP room. When I right-click on the clips in the COLOR room there is no option for RD3 settings. How do I get this installed?
    Dwaine Maggart replied 14 years, 4 months ago 2 Members · 6 Replies
  • Dwaine Maggart
    May 23, 2012 at 8:34 pm
    Do you see the clips OK on the Browse page, in the Browse page viewer? What type of system are you on? What type of graphics card(s)/chipset does your system have? How much VRAM does the graphics card(s)/chipset have?
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Andy Matthias
    May 23, 2012 at 8:41 pm
    I actually cannot see the clips in any window. I’ll sometimes get a frame of image distortion but thats it.
    I’m working on a MacPro with the latest OS (10.7.4) and the latest version of Resolve Lite. I have an ATI Radeon HD 5770 1024 MB video card.
  • Dwaine Maggart
    May 23, 2012 at 9:02 pm
    Are you using the 8.2.1 beta 3 version of Resolve Lite? That’s what you HAVE to use if you’ve done the OSX 10.7.4 update and have an ATI card.
    Dwaine Maggart
  • Andy Matthias
    May 23, 2012 at 9:06 pm
    Downloading it now. I didn’t realize there was a recent update. I’ll try it and let you know.
  • Andy Matthias
    May 24, 2012 at 1:07 pm
    Thanks Dwaine, that solved it. Did they get rid of RED support for 8.2 cause I thought it had settings for RED in 8.1?
  • Dwaine Maggart
    May 24, 2012 at 3:48 pm
    Nothing to do with Red support. The OSX 10.7.4 update created an issue with the Resolve openCL GPU handling that we use with AMD/ATI GPU cards/chipsets. 8.2.1 beta 3 has a fix for the issue.
    If you were running OSX 10.7.3, then Resolve 8.2 would have worked OK for you.
    Dwaine Maggart
