Activity › Forums › Apple Final Cut Pro Legacy › Using “R” or “TM” in Text
  • Using “R” or “TM” in Text
    Posted by Scott Sniffen on July 31, 2008 at 1:59 pm
    Is there a simple way of putting the registered R or TM in using text? I can get them in but only full size, not small and in the corner they way they are designed to be used.
    Scott Sniffen
    Andy Mees replied 18 years, 1 month ago 4 Members · 5 Replies
  • Andy Mees
    July 31, 2008 at 2:09 pm
    you can access all thes and ore directly from OS X’s Character Palette
    that said, on my machine ™ is Option-2 and ® is Option R
  • Scott Sniffen
    July 31, 2008 at 2:28 pm
    Understood. But when you apply them, they appear full size and not smaller and higher in the text line. Is there a way to apply these symbols correctly as used in the print world.
    Scott
  • Todd Reid
    July 31, 2008 at 2:32 pm
    If you use the Boris 3d Text, you can adjust each character individually, including the smaller size and baseline (which should raise it like your wanting).
    FCP’s title doesn’t allow this to my knowledge, so I just usually leave a space and add another text layer.,
    Boris is the easier, more convenient way.
  • Chuck Reti
    July 31, 2008 at 3:19 pm
    [Scott Sniffen] “…when you apply them, they appear full size and not smaller and higher in the text line.”
    Trying this in FCP 5.1.4, with both FCP Text and Boris Title 3D, with a number of fonts, the “TM” is properly superscript, which is how it it built, and the “R” is same height as normal characters, which is how I usually see it used in print. Same observed just placing these characters in TextEdit and other word processing apps.
  • Andy Mees
    July 31, 2008 at 4:46 pm
    well it works exactly as it should (superscript etc) on my system using Apple’s own Text Video Generator
