Activity Forums Avid Media Composer Using Quicktime clips with Avid Media Composer 3.0
  • Using Quicktime clips with Avid Media Composer 3.0
    Posted by Richard Strom on August 6, 2009 at 6:43 pm
    Hello all, I’m usually working in FCP and did capture a bunch of clips as Quicktime movies. Unluckily, I have to edit them on an Avid rental system which I am only little used to. Importing the QT Files into Avid takes ages. I tried several converters using different codecs including Super which was recommended somewhere in this forum, but I always get the message that the format is not supported. I would love to have an external encoder so that I’m able to continue working on the Avid. Does anybody have a clue to accomplish that in the fastest and most painless way?
    Cheers
    Dennis
    Richard Strom replied 17 years ago 2 Members · 2 Replies
  • Job Ter burg
    August 6, 2009 at 7:36 pm
    What codec are the QT’s in now? The best way to get fast imports into Avid is to create QT’s in a flavor of the Avid codec. There are a hand full of SD and HD resolutions, so it depends on your source and destination which one to choose. On a fast machine, a transcode to Avid codec should not take insanely long.
  • Richard Strom
    August 7, 2009 at 1:29 pm
    The QTs are in DV-PAL format and will import with the same project settings – files are between 1 and 15 GB. Is there any workflow idea to downsample the clips and relink them later to HQ media? Cheers
    Dennis
