Activity Forums Apple Final Cut Pro Legacy Using QTs from AVID in FCP
  • Using QTs from AVID in FCP
    Posted by Jonah Maddox on November 6, 2008 at 4:26 pm
    I have some quicktimes that were rendered out for me from an avid system, they look like normal quicktimes and want to open using quicktime
    but when they do they just show white. I opened them with FCP and got the same, then with VLC and I could see the start image but it never played.
    Is the a way to convert these into QTs that a mac will like. I did try exporting them from QT but it says qtKitErrorCatchAll(-8961)
    Any suggestions?
    Jo
    Michael Hancock replied 17 years, 10 months ago 2 Members · 1 Reply
  • Michael Hancock
    November 6, 2008 at 5:37 pm
    They were probably rendered out using the Avid codecs, which you don’t have installed (hence the white screen).
    Download them here, install them, and your quicktime should play:
    Avid Codecs at Bottom of the Page
    Michael.
