Activity Forums Apple Final Cut Pro Legacy Using QT Reference Files to Make and edit Multi clip
  • Using QT Reference Files to Make and edit Multi clip
    Posted by Adam Berch on March 21, 2016 at 4:52 pm
    I use Pluraleyes to sync 3 or 4 cameras as well as an H4n Audio file. After the sync is done, I put it onto the timeline and I want to make a Multiclip from the synced slips.
    Here’s what I do: I export each track and it’s audio separately (just for reference) as a Quicktime Reference File. I do this for all 3 cameras.
    Then I make the Multiclip and have it start at the In Points. It’s been working great.
    Is this the best way to do this? I eventually make a DVD from it so the whole timeline gets encoded anyway.
    Shane Ross replied 10 years, 6 months ago 2 Members · 1 Reply
  • Shane Ross
    March 21, 2016 at 4:54 pm
    No. Never export QT reference files and reimport for use in a project. They are fragile. They are really only meant to be used to make quick exports to take into Compressor. To be used quickly. If you put one into a project, and some media from it gets moved, or anything…it’ll stop working, and there’s no way to fix them.
    Shane
    Little Frog Post
