Activity Forums Canon DSLR Cameras Using proxies from DNG
  • Using proxies from DNG
    Posted by Alex Gat on June 2, 2015 at 12:24 pm
    Hello all,
    I jave just finished a raw production and I am now preparing the editing process.
    I have converted the raw files form ML into DNG files for Davinci. I will do a quick look and will export them into prores to edit in Premiere.
    My question : I will edit with prores files. When done, I will go back to Davinci for color grading. When that moment comes, will I be able to swap my prores files with the DNG ones ? Is that the whole principle of proxies ? I think it is but I wanted to be sure.
    I want my movie to be a black and white one. Obviously I have shoot in color and will do some channel mixing to go from color to B&W when the time comes. But I want to edit in B&W, so I wanted to do a simple desaturation when converting my DNG to prores. That is why I’d like to be sure that I will be able to swap the prores files with the DNG ones when my edit is completed.
    Thanks for your replies.
    Alex
    Warren Eig replied 11 years, 2 months ago 2 Members · 2 Replies
  • Alex Gat
    June 7, 2015 at 12:26 pm
    Hello,
    I did not receive an answer to my post, so I send it at the top again.
    My question is :
    Is the conversion from DNG to prores only to edit ? Will I be able to get back to the DNG files when color grading ? Is such case I don’t need to worry too much if I did not get the white balance right or any other adjustement when I created my prores proxies.
    thanks.
    Alex
  • Warren Eig
    June 7, 2015 at 6:10 pm
    Yes, you should be able to go back to the original DNG. It is a bit like working with Red footage. You edit the progress then relink to the original files.
    Warren Eig
    O 310-470-0905
    email: warren@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    REEL: https://www.babyboompictures.com/BabyBoomPictures/Reels.html
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
