Activity Forums Adobe After Effects Using Premiere Pro file in after effects
  • Using Premiere Pro file in after effects
    Posted by Emily Scollon on March 5, 2012 at 4:21 pm
    When i bring in the Premiere file to After effects by importing i can see the file in the preview, but i cannot drop it in the timeline.
    When i use the dynamic linking option between the programs to bring the premiere file in i can then put it in the timeline, but it is only giving me white and not bringing in the footage from the premiere sequence.
    Am i missing something?
    thank you!!!
    Emily Scollon replied 14 years, 6 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    March 5, 2012 at 7:01 pm
    Here’s my workflow:
    Edit in PPro. If I want control over each clip, I right click on them one at a time and create a AE composition. I do my fx in AE, keep the project open and save. The next clip I work in AE will open in the same comp- this way I can copy and paste settings if I need to. If I want to apply a plugin to the whole cut, I create a new Sequence In PPro, bring in my first sequence (my edit) in it. It comes in as a clip that can then be sent to AE for fx. I can still change the cut inside the first sequence if I need to.
    It will take longer to render in PPro for previews because of the AE fx.
    You can also open a Premiere project in AE or import one.
    Just make sure you have the latest updates for both AE and PPro.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Emily Scollon
    March 15, 2012 at 6:20 pm
    can you clarify this part: “If I want to apply a plugin to the whole cut, I create a new Sequence In PPro, bring in my first sequence (my edit) in it. It comes in as a clip that can then be sent to AE for fx. I can still change the cut inside the first sequence if I need to.”
    Can you also explain what you would be copying and pasting settings for?
    I’m sort of new at this but really would like to understand. I appreciate your patience 🙂
