Activity Forums Apple Final Cut Pro Legacy Using Plural Eyes the right way
  • Using Plural Eyes the right way
    Posted by Sascha Engel on January 2, 2013 at 12:29 pm
    Hallo Everybody,
    first of all a Happy New Year to all of you!
    I have a Q regarding the software Plural Eyes. I just shot a movie in the states (DP) of which I am also the editor.
    We shot on a Mark lll and recorded the sound separately on an AUDIO DEVICES recorder, so I have hundres of MOV Video and WAV sound files.
    Even though I am very good at syncing, I do not wanna do this to myself manually, so I want to give Plural Eyes a shot.
    What would be the best way to do it? Edit the movie with on board sound first, then put the sound files of the Sound Man in the time line? Will it be able to match, even though in the Sequence I just use bits of the the full clip? Or better to sync up first all footage from the browser? And if that’s the way, how to techically do that?
    Thanx for any advice!
    I am dealing with about 900 clips, shot with Mark lll, Panasonic TM900 & a Sony MiniHD Cam. The footage I first transcoded with Log & Transfer Tool.
    Thanx.
    Sascha
    Samuel Enblom replied 12 years, 12 months ago 5 Members · 15 Replies
  • 15 Replies
  • Roli Rivelino
    January 3, 2013 at 8:06 pm
    As long as you have corresponding timecodes Plural Eyes sorts it, so edit with onboard first and then get Plural to do its magic. Test it with a couple of random minutes first just to make sure.
    https://www.rolirivelino.com/
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
  • Sascha Engel
    January 5, 2013 at 9:08 pm
    Hi Roli,
    can I ask you for a more detailed explanation?
    What do you mean by corresponding Time Codes? I Have a slate and clap before each take, but the Audio recorder and the Mark lll had no synced Time Codes.
    So you would edit with the onboard sound, and then throw the right sound clips in the rough are of the Video and let PE sync it then?
    I am not sure, I fully understood your workflow.
    Thanx if you could elaborate more.
    Sascha
  • Andrew Drachman
    January 7, 2013 at 6:43 pm
    Hi Sascha,
    I have used PluralEyes for every project I’ve edited that needed to have the audio recorded externally. I’ve found the best way to use the correct audio is to sync everything up beforehand, and edit using the better audio already synced.
    It may take some time to sync a lot of footage, but I think it would ultimately take less time than syncing the audio post-edit (especially if your are jumping back and forth chronologically).
    Andrew
  • Roli Rivelino
    January 7, 2013 at 7:09 pm
    Hi Sorry for the delay Sacha, have been away. I think my answer is now defunct anyway as Andrew has more experience with it than me. I just used it once for a short project; I’d go with his answer.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Sascha Engel
    January 7, 2013 at 8:16 pm
    Can you explain, in a step by step way, how to connect all the master clips with the WAV files and also how I could safe & merge those as one clip then – if it’s not too much asked.
    Thanx.
    Sascha
  • Andrew Drachman
    January 7, 2013 at 10:07 pm
    I am unsure what you mean by master clips and not all of my external audio is done in .wav format; so I will describe my syncing process. Also, keeping in mind that the majority of my editing has been done in either Premiere Pro or Final Cut 7, I can’t be certain the same steps would work in FCPX (although I can’t imagine it would be very different).
    1. Import all media that needs to be synced
    2. Create a sequence (or project in FCPX) and label it so I know that it is my sequence that will be synced (I put “PRESYNC_PROJECTNAME” to identify my pre-Pluraleyes sequence).
    3. Drag all video from one camera angle to the sequence IN CHRONOLOGICAL ORDER. For separate camera angles, you want to use separate tracks. Camera A all goes on video on track 1, camera b all goes on video track 2, etc. Make sure all of the audio from these cameras go on their own separate tracks as well because that is what Pluraleyes uses to sync everything up.
    4. Bring the externally recorded audio on to it’s own separate track.
    5. Export the sequence as an XML to be brought in to Pluraleyes and make sure that the matching sequence is correct.
    6. Check off the necessary boxes (Clips are in Chronological Order, Try Really Hard, etc.)
    7. Press sync, pull in the synced clip in to your editing program and you should be all set.
    In terms of making sure the clips stick together, I either group them within the program or move clips with caution when editing. I like to keep all of my audio tracks (even if I don’t plan on using them) and mute them just in case the natural audio is needed.
    Andrew
  • Sascha Engel
    January 8, 2013 at 12:18 am
    Thanx for your time for the detailed run through.
    Another Question: Does that mean, I can also somehow merge them so I have a new “subclip” in the Browser, which is containing the synced Audio clip, so I can use them in different Sequences if needed?
    Thanx.
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
  • Sascha Engel
    January 8, 2013 at 12:20 am
    ..and it was good for FCP 7 – I do not use FCPniX – only Premiere and 7.
    Sascha Engel
  • Andrew Drachman
    January 8, 2013 at 2:39 am
    Not that I know of. I just copy and paste when I want to do that.
  • Sascha Engel
    January 8, 2013 at 8:36 am
    But your workflow, needs to make already a decision of shots and putting it roughly into the right order in the TL.
    But let’s say I have 7 takes from the same scene and I have no idea yet, how I wanna edit it, but I’d like all the master clips in the Browser to be paired, synced and merged with the right audio files, is there a way to do that?
    Thanx.
    Sascha Engel
