Activity Forums Apple Final Cut Pro Legacy Using Plug Ins
  • Posted by Tony Fields on August 20, 2009 at 10:17 pm
    I have recently downloaded some free plug-ins, but for the life of me, I can’t figure out how to actually use the things. I put one in the plug-ins folder, but when I double-click it, I get a “file error: wrong type” error messasge in my FCP project.
    Tony Fields replied 17 years ago 2 Members · 2 Replies
  • Shane Ross
    August 21, 2009 at 1:36 am
    After you install them into the HARD DRIVE>LIBRARY>APPLICATION SUPPORT>FINAL CUT PRO SYSTEM SUPPORT>PLUGINS folder, you then see them after you open FCP. They will be in the EFFECTS tab…organized however they choose to be. Finding them that way….well, you can go to that tab and press CMD-F and type in the name and that will find it.
    Shane
  • Tony Fields
    August 21, 2009 at 6:12 pm
    Thanks a lot!
