Activity Forums Adobe Photoshop Using Photoshop to convert an image from Indesign to jpg
  • Using Photoshop to convert an image from Indesign to jpg
    Posted by Nicole Bar on February 15, 2009 at 4:36 am
    I am trying to convert an image which I have in Indesign to jpg. The quality in Indesign is fine but once I convert to jpg (via export to photoshop) the quality deteriorates and the edges are jagged. I think the problem might be with the way that I am saving in Photoshop. I need the image in 300 dpi so I export it to Photoshop at around 600 or 1200 dpi then reduce it to 300 dpi. I am not sure if this is the way to do it.
    I would appreciate any assistance in correcting the problem.
    Matt Sepeta replied 17 years, 6 months ago 2 Members · 1 Reply
  • Matt Sepeta
    March 2, 2009 at 4:12 pm
    Why do you need a jpeg in 300dpi? I assume you are printing it, so why not just export it as a pdf and print it? I have never had any problems doing that
    24″ Imac | 2.8 ghz duo | 4 gb
    Mac Book | 2.2 ghz | 2 gb
    pscs4 | idcs3 | macromedia suite 2004 | fcp5
