Using Particle Illusion with Flash 8
I want to use particle Illusion with flash, but I want to keep the swf filesize as small as possible. I export the particleillusion as a sequence of PNG’s. I then import those png’s to After effects and put the quality low which helps to reduce the filesize. When I import a normal 200 frame animation (320px by 240px) into the flash however, I still get a flash that is over a megabyte just for this simple short animation…
Is there anyone here that uses ParticleIllusion with flash that could possible help me out with ways to DRASTICALLY reduce the filesize when using them with Flash.
Thank you,
Michael
