Activity › Forums › Apple Final Cut Pro › Using PAL anamorphic clips in 1080 storyline
  • Using PAL anamorphic clips in 1080 storyline
    Posted by José luis Martínez díaz on June 24, 2011 at 6:54 pm
    I’m trying to use anamorphic pal clips in a HD storyline, but the spatial conform feature just allow a fit or fill approach, cropping the image and not deanamorphising. I got a workaround by using distort, but need to apply it to a bunch of clips, and it only works in the timeline, not in the event library… Some kind of conform command, ala after effects will be quite useful.
    Any ideas?
    Jose
    Geert Van den berg replied 15 years, 3 months ago 3 Members · 3 Replies
  • Simon Ubsdell
    June 24, 2011 at 7:24 pm
    I’d say the easiest thing would be to fix one clip in the timeline then copy and paste the attributes (Cmd/C then Cmd/Opt/V) to the other clips that need fixing. Same as did in FCP7, but note that all properties get pasted and you can’t choose which, so do it before you’ve added any specific filters to your first clip.
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
  • José luis Martínez díaz
    June 25, 2011 at 3:18 pm
    Thanks for your answer.
    I really hope there’s some simplest way, because it’s 13 hours of footage, and almost 70% of it was PAL 16/9…
    If this is the future I’m afraid I’ll go the way of dinosaurs…
  • Geert Van den berg
    June 26, 2011 at 4:13 pm
    I think that this spatial conform option is not completely finished. I am also trying to tackle this problem. Not for a real project yet, but without it, the application is even less usefull than it already appeared to be.
    ProRes material that is run via Compressor with a 16×9 tag will work in an anamorphic project, but I tried the same thing with the IMX codec, because we have a lot of IMX material on our server and then it didn’t work. (I don’t want to re-transcode all our material anyway, but it was just a test to see if it would work).
    When done with a ProRes clip, FCPX also did not have to render the timeline, just as in FCP 7 was the case. If you use distort it will need to render.
    Dropping an SD PAL ProRes clip which has been transcoded with Compressor with a proper 16×9 tag will also scale correctly in am HD project, it will need to render for the upscaling though.
