Activity Forums Avid Media Composer Using Paint Bruch / Scratch Removal Effect
  • Using Paint Bruch / Scratch Removal Effect
    Posted by Avi Lev on June 26, 2013 at 3:40 pm
    Hi
    Take a look at this short shot in the link
    https://youtu.be/WUCwpjeXhQ8
    It is one of many
    that was taken in the Sahara desert with a defective Sony HDR-PJ650 bought Apri 22 2013 brand new. The camera leaves a visible spots inside the frame (it is NOT a dirty lens!)
    Now, editing on the Avid Composer 5.0.4.4 I’m trying to remove the spots using the Paint Brush Effect and the Scratch Removal Effect, yet, the Tracking tool is not fast enough to follow the spots movements.
    Is there any other way to remove the spots?
    Thanks, Avi
    Ronen Pestes replied 13 years, 2 months ago 2 Members · 1 Reply
  • Ronen Pestes
    June 27, 2013 at 8:27 am
    you will need to manually create add edits and pull clean area from before or after the spot.
    or use another software like PFclean.
    you can also try some of the BCC restoration effects.
    Ronen
