Activity Forums Adobe After Effects Using only part of a long clip
  • Using only part of a long clip
    Posted by Bill Nahlik on September 1, 2009 at 12:31 pm
    When I load a long clip into the viewer window and mark an in point, I would like to drop that clip into my timeline beginning at that in point.
    I know I can scrub through the clip in the comp window, but an 8 minute source clip takes a while to scrub in a 30 second comp!
    Bill Nahlik replied 17 years ago 2 Members · 2 Replies
  • Todd Kopriva
    September 1, 2009 at 3:36 pm
    You can trim a footage item in the Footage panel to do what you describe.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Bill Nahlik
    September 1, 2009 at 3:52 pm
    Thanks, Todd. It’s the putting it in the comp first that is the step I was missing. Double-click on the layer in the comp window, then adjust it in the viewer window.
