Activity Forums Adobe After Effects using one 3d model in a AE animation
  • using one 3d model in a AE animation
    Posted by Tielman Dewaele on March 5, 2007 at 9:31 pm
    Hello,
    Im making this animation with an illustration i have made. It is fully AE, but i want to use one model, a tv, thats made in C4D.
    In AE i use a fast cameramovement to a house. In the house the character is wathing tv. When the camera is at the illustration, the camera turns slowly to the tv and shows a logo. So youlle have to see the tv is indeed 3d and turns with the cammove in AE.
    How would i achieve this?
    (Its the first time i combine the softwares)
    Dhr T.
    Peace
    Majorasshole replied 19 years, 6 months ago 3 Members · 2 Replies
  • Captain Mench
    March 5, 2007 at 9:53 pm
    I did something with a 3d model a long time ago and I seem to remember the key was to use it as a 2d image.
    You might also try exporting your camera data from AE… search here for some posts on that as it’s a little confusing… and then use that data in C4D to map a camera move… then, just export/import it as an element.
    Good luck,
    CaptM
  • Majorasshole
    March 6, 2007 at 6:42 am
    render out your AE footage to a movie
    bring that into C4D as a backbround
    animate your 3d model TV to match.
    turn off the background and render out as a movie or image sequence with an alpha channel.
    if you need Z depth for 3d fog etc you can render out as an rpf image sequence.
