Activity › Forums › Apple Final Cut Pro Legacy › Using offline clips for sound editing
  • Using offline clips for sound editing
    Posted by John Pastuch on December 2, 2010 at 4:57 am
    Wasn’t exactly sure where to put this, but since I edited my film in FCP and it’s concerning frame rates…
    OK, so I’ve been editing a movie I shot on the DVX100 in 24pA mode. I did everything in FCP correctly, on the correct timeline, and got a 24p end product (and yes, I edited on a 23.98 timeline).
    So, when it came time to export a picture for sound editing in Reaper, what I did was export a high quality .mov from the timeline. Then, I took that .mov and converted it to a smaller, lower quality .avi that would run fast on my PC (I had to edit the sound on a PC, but the picture on a Mac, unfortunately).
    So, when it prompted me for the frame rate of the avi, I entered “23.976” because I wanted to be as exact as possible.
    I imported the .avi into Reaper, went frame by frame, and saw that each second on the counter had 24 frames exactly. To be double sure, I put together 30 secs of sound fx work using Reaper, exported it as a high-quality WAV, then imported the WAV into FCP to see if it matched up frame by frame…and it did.
    But I happened to look at the properties of the .avi the other day and noticed the frame rate read “23 fps”. Now, I know each second in my Reaper timeline counter 24 frames starting at zero each time, but I was wondering if I should be worried about this…when exporting from something like MPEG streamclip, I should be using 23.976 and letting the software round however which way, no? Or should I have put 24fps? Does any of this really make a difference? Will my sync eventually be off using this reference .avi?
    David Roth weiss replied 15 years, 10 months ago 2 Members · 1 Reply
  • David Roth weiss
    December 2, 2010 at 12:26 pm
    Certainly doesn’t sound right. You’ll have to do your testing with longer pieces than 30 seconds.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
