Activity Forums Boris FX Particle Illusion Using NOT black background?
  • Using NOT black background?
    Posted by Steve Stryker on March 6, 2009 at 11:57 pm
    Hi again,
    Ok I am still very much a noob at all this.
    I am doing a chroma key project.
    I have the keying done well.
    I am using Sony Vegas Pro 8
    For the background I am using “cloudy sky”
    Proble: the particle Illusions look washed out on the white background. Is there (what) am I missing or not setting up correctly?
    Steve
    Sony Vegas, Particle Illusion, NOOB!
    Steve Stryker replied 17 years, 6 months ago 2 Members · 2 Replies
  • Alan Lorence
    March 9, 2009 at 2:15 pm
    I’m not sure as you haven’t given enough details, but try these things:
    – In particleIllusion, render on black background, then when you check “save alpha” in the output options dialog, make sure “remove black…” is checked.
    – You can edit the properties of the emitter itself — double click it on the stage to open the properties dialog, then click the “particles” tab, and check the “preserve color” option that’s next to “intense”.
    Alan.
    http://www.wondertouch.com
  • Steve Stryker
    March 11, 2009 at 7:14 pm
    Thanks, I will try them. I have some time in the next few days.
