Activity Forums Apple Final Cut Pro Legacy using MXO2 instead of Compressor to change fps rate?
  • using MXO2 instead of Compressor to change fps rate?
    Posted by Nicholas Natteau on June 12, 2010 at 10:09 pm
    Wondering if there was a way I could avoid using Compressor to change the fps rate of some footage, since this would take ages, I decided on a whim to use my Matrox MXO2 and was very pleased with the results.
    I had a bunch of WWII footage (originally shot 24p) copied by the National Archives for me onto mini-DV tapes (480i29.97). I took the 480i29.97 footage and upconverted via MXO2 to 720p23.98.
    I was amazed to see how good the result was.
    So my question: If you have footage originally shot at 24p but transferred to DV tapes at 29.97fps, why
    use Compressor if you can make fps rate change from 29.97 to 24p with the MXO2 in real time?
    Or am I missing something?
    Shane Ross replied 16 years, 3 months ago 5 Members · 16 Replies
  • 16 Replies
  • Shane Ross
    June 12, 2010 at 11:29 pm
    Wait…the MXO 2 does a frame rate conversion as well as the upconvert?
    Hmmm…this bears testing. Thanks for trying this and pointing it out.
    Shane
  • Arnie Schlissel
    June 12, 2010 at 11:31 pm
    Sounds more like it was removing pulldown.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Shane Ross
    June 13, 2010 at 12:10 am
    Even then, my tests with the Kona showed me bad results when I tried. The footage captured out of sync and slow motion. Well, by “tests” I mean “mistakenly had the settings wrong.”
    Shane
  • Nicholas Natteau
    June 13, 2010 at 12:13 am
    Hi Shane,
    Yes, as far as I can tell. I’ll post a couple seconds of my upconverted footage.
    But I was amazed! In FCP’s Log and Capture window, all I did was select “MXO2 Apple Pro Res 720p23.98” as my upconvert. My 480i29.97 clip became a 720p23.98 clip in the browser with “23.98” in the fps column. I remember you had mentioned that 720p.29.97 was unnatural, that I should either use “720p59.94” or 720p24 but not “720p29.97”
    Interestingly I didn’t find any problems selecting “720p29.97” essentially 720p30. Except that now and again (every 6 or 7 frames) I seemed to have a duplicate frame.
    The problem with upconverting to “720p59.94” was that I essentially ended up with twice the number of frames…every second frame being a duplicate of the preceding one. So that if I advanced frame by frame in my resulting 59.94 timeline, movement would stop at every second frame and resume after.
    But after selecting “720p23.98” for my upconvert via MXO2, I had a perfect frame rate, no duplicate frames. Of course I’m talking about footage that was originally shot 24p (WWII) but transferred to mini-DV tapes at 480i29.97
    Best,
    – Nick
  • Nicholas Natteau
    June 13, 2010 at 12:15 am
    I didn’t know Kona 3 had that option. I have Kona LHi and my only options with that card are “720p59.94”, 1080i29.97 and 1080psf24. But MXO2 seems to have more upconvert options.
    How many upconvert options does Kona 3 have?
  • Shane Ross
    June 13, 2010 at 1:00 am
    The ones you see in the LHi…
    Shane
  • Thomas Morter-laing
    June 13, 2010 at 7:12 am
    Sorry I don’t understand here- is the MXO2 like a physical thing? Whereas compressor is software? If so surely that’s why people choos compressor, cos it’s cheaper not to buy something else?
    Tom Morter-Laing
    Certified Apple Product Proffessional, 2010
    Production Assistant, Grace Productions
    Degree; TV Production
  • Shane Ross
    June 13, 2010 at 9:18 am
    [Thomas Morter-Laing] “Sorry I don’t understand here- is the MXO2 like a physical thing?”
    Yup…
    https://www.matrox.com/video/en/products/mac/mxo2_family/
    [Thomas Morter-Laing] “Whereas compressor is software?”
    Yup.
    [Thomas Morter-Laing] “If so surely that’s why people choos compressor, cos it’s cheaper not to buy something else?
    Compressor takes time…a LOT of time…to upconvert footage and make it look good. And it takes a lot of tweaking, and trial and error to get the right settings. And if you have a LOT of footage, it takes longer and longer. Whereas hardware upconversion is realtime, when you capture, and very clean.
    Depends on how much your time is worth. Me, I’d rather be editing then waiting for footage to compress.
    Shane
    June 13, 2010 at 10:37 am
    “If you have footage originally shot at 24p but transferred to DV tapes at 29.97fps, why
    use Compressor if you can make fps rate change from 29.97 to 24p with the MXO2 in real time?”
    Yeah sorry, the only reason I bough that up was because his above question says’ why use compressor?’ so my answer is: “to save £1249 (ish)” heheh 😀
    But yeah fair enough, if you have the funds then I’m sure even MXO(1) would be a very useful thing to have!
    Tom Morter-Laing
  • Bj Ahlen
    June 13, 2010 at 6:49 pm
    [Nicholas Natteau] “But after selecting “720p23.98” for my upconvert via MXO2, I had a perfect frame rate, no duplicate frames. Of course I’m talking about footage that was originally shot 24p (WWII) but transferred to mini-DV tapes at 480i29.97 “
    I suspect the MXO2 in this case correctly guessed (or tested) that your source footage had pulldown, so it removed the skanky frames and and generated 480p23.98 on the fly and converted that to 720p23.98 at the output.
    The same thing can of course be done with software only.
    How much time did it take with the MXO2?
    (Processing time per second of source footage.)
