Activity Forums Audio Using Multiple Mic with Sennheiser EW 100 G2
  • Using Multiple Mic with Sennheiser EW 100 G2
    Posted by Alistair Gallop on October 5, 2011 at 8:16 pm
    Hi Guys,
    I am having a bit of trouble: My system set up is as follows:
    1no. EW100 G2 True Diversity Receiver
    2.no EW100 G2 Body pack receiver.
    2.no ME2 lapel mics going into the body packs.
    Each mic when switched on independently works fine and I pick up a good sound.
    However when both body packs are on, we get a weird interference swishy sound?
    I saw on the net that we should have the 2 body packs 50 mhz apart so we tried that but when we do this the 2 mics dont get picked up, they only work again when one is turned off.
    Can I just confirm that this system can work with 2 mics?
    Thanks it advance, I am missing out on a whole night of filming so any tips would be greatly appreciated!
    Alistair
    Stanya Kahn replied 13 years, 2 months ago 4 Members · 13 Replies
  • 13 Replies
  • Eric Toline
    October 5, 2011 at 8:32 pm
    When you change the transmitter frequency you have to change the receiver frequency to match.
    Eric
  • Eric Toline
    October 5, 2011 at 8:38 pm
    Each set of tx and rx have to be on different frequencys from each other. Example: Set #1 tx & rx on 540.00, Set #2 tx & rx on 541.00.
    What frequencys do you have on your tx & rx now?
    Eric
  • Alistair Gallop
    October 5, 2011 at 8:45 pm
    Hi Eric,
    I only have 1 receiver? I currently have that on 840.400
    I then have 1 body pack on 840.375
    The other bosy pack on 840.425
    This way they are 50mhz apart but this is working? Are you saying I need an additional receiver?
    Alistair
  • Brian Reynolds
    October 5, 2011 at 8:57 pm
    You MUST have a receiver for EACH transmitter……….
    Radio mic systems work as a matched pair, the Transmitter sends to the Receiver that is tuned to it.
    You can never, never, never send 2 transmitters to one receiver it just wont work.
    The difference between Knowledge and Wisdom is… Knowledge is the knowing of facts…. Wisdom is the sensible application of good quality knowledge…
  • Eric Toline
    October 5, 2011 at 9:39 pm
    2 tx & 1 RX? Not going to work that way. As others have said you need a receiver for each transmitter.
    Eric
  • Alistair Gallop
    October 5, 2011 at 9:57 pm
    Ok guys thanks for your help, how about this then:
    I have an adapter MZA900 which allows me to connect my body pack directly into a Tascam Dr 100 via XLR. If I was to buy another of these adaptors for the other body pack and connected this to the other XLR connection on the Tascam would this work?
    Im guessing that because the 2 xlr connections are left and right, this would record each of the mics onto seperate channels but I could then edit these in final cut by copying them to both channels?
    Alistair
  • Eric Toline
    October 6, 2011 at 12:40 am
    If by body pack you mean the transmitters then it’s still NO. You need a receiver for each transmitter to demodulate the RF signal from the tx. Look stop trying to change the laws of physics. Go out and buy another receiver.
    Eric
  • Eric Toline
    October 6, 2011 at 12:45 am
    ok, Two Mza900’s will allow you to put each lav mic on a different channel but you’ll no longer be wireless from the talent to the camera. If your camera has 48v phantom power you’re good to go with a couple of 25″ xlr cables.
    Eric
  • Alistair Gallop
    October 6, 2011 at 8:21 am
    Of course I would love another receiver but they will be illegal next year so might aswell wait until I can afford a whole new system!
    Im an entrepreneur always trying to work as efficient.
    Alistair
  • Eric Toline
    October 6, 2011 at 1:17 pm
    Ok, I understand your dilemma. Then the only way to use two lavs would be to get two MZA’s and hard wire them to the camera or recorder.
    Eric
