using Motion Tracking for set extensions
Hi!
I’ve been trying to do motion-tracking with AE for about 2 weeks now. I have viewed a LOT of tutorials about the subject, including Mocha tutorials, but still – it seems that any method i try to use with motion tracking, fails.
to be a little more specific: I’ve been trying to motion track panning shots, and pull a set extension on it using matte-painting with Photoshop. My problem is that i always end up getting the still-painting(that was imported to AE from PS) jittery, move a little bit, rotate a little etc. – basically anything but stay pinned to the spot i want it to be.
https://www.youtube.com/watch?v=yBZsokMCCaI&feature=youtu.be
In this link you can see my basic type of tries and the result i always get.(I tried to use both AE built-in motion tracking and Mocha. Mocha does a better job but still the result is looking like in the link)What i did in the link above is one of the methods i read about:
I scrolled to the last frame and added X-Spline layer and drew a 4-point rectangle on the surface -> then hit ‘track backwards’ and stop when the layer seemed to be getting out of the screen. I continued that way(adding layers etc.) until the end of the tracking(until the first frame).
Then i took each layer and copied the Transform data and pasted it to a corresponding null object at the exact same frame. Each layer had its own null. So the first null corresponds to the LAST third of the pan-shot and so on. Then i parented null3 to null2 and null2 to null1. Lastly i imported the layer i made in PS and then parented it to null3.
As you can see this method did not work for me.In Mocha, I also tried to create a X-Spline layer and change the “link to track” option to none, and then link the other layers to that first layer – still it ends up looking like that!
Please help because this is driving me insane!
What am i doing wrong??
