Activity Forums Apple Final Cut Pro Legacy Using mixed footage in single timeline?
  • Using mixed footage in single timeline?
    Posted by Daniel Grixti on June 25, 2010 at 4:40 pm
    Hi there,
    I am trying to edit footage from a Canon 7D and JVC in the same timeline. The 7D is encoded with h.264 and the JVC is XDCAM I think (this is the compressor that FCP is using when I look in the sequence settings menu).
    If I import the footage and get FCP to adapt the settings to match the 7D footage then when I import the JVC footage it is unrendered’. Similarly, if I use the JVC settings then the 7D footage comes up as ‘unrendered’. If I have footage from both cameras side by side on the timeline and I select h.264 compression in the project settings then the 7D footage can be viewed but the JVC remains unrendered and visa virsa.
    How can I get both bits of footage in the timeline where neither need to be rendered. How can I use two different compressions in the same timeline?
    Shane Ross replied 16 years, 2 months ago 2 Members · 1 Reply
  • Shane Ross
    June 25, 2010 at 4:50 pm
    #1 – Do not edit the footage from the Canon 7D natively. H.264 is NOT an editing codec. It is preocessor intensive, and REALLY bogs down the machine.
    #2 – do not convert it to XDCAM…that is a highly compressed format of it’s own.
    Best to convert the 7D footage to ProRes…either with the Canon EOS Log and Transfer plugin, or by using MPEG STREAMCLIP or Compressor. But I like the plugin because it brings in TIMECODE and a REEL NUMBER. HUGELY important things.
    https://www.usa.canon.com/dlc/controller?act=GetArticleAct&articleID=3249
    Then work in a ProRes timeline. Yes, you will have to render the JVC footage, but really not until the end. You can work with it fine in a ProRes timeline.
    Shane
