Activity › Forums › Avid Media Composer › Using MC5 to capture live video as DNxHD36?
  • Using MC5 to capture live video as DNxHD36?
    Posted by Ben Schwartz on August 5, 2011 at 11:38 pm
    I am looking to capture live HD-SDI 1080 23.98PsF video directly as DNxHD 36. I understand that DNx is an intermediate codec, but is this not possible to do? I saw that the AJA Io Express interfaces with Media Composer:
    https://www.aja.com/pdf/AJA_Avid_MC_Solution.pdf
    I work a lot with the Arri Alexa, and post production frequently requests DNxHD 36 transcodes for offline. I typically create LUTs on set, and I want to bake in these LUTs over the Log C stream, maintain naming structure and timecode, AND output Quicktimes as DNxHD36. Is this possible?
    Ben Schwartz replied 15 years, 1 month ago 2 Members · 2 Replies
  • Michael Phillips
    August 6, 2011 at 1:07 am
    You certainly can capture DNxHD36 from a live HD-SDI stream with Avid hardware or AJA i/o Express. Or you could capture via a Cinedeck or Sound Devices type device directly to DNxHD 36.
    Are you planning on inserting the LUT into the HD-SDI stream with something like an HDLinkPro? make sure you don’t have any frame delays. Also, what will the common source ID be for the image being captured?
    Unless the filename is being inserted into the HD-SDI and decoded, you will only have timecode – but to which file will be lost. I know the RED camera inserts this into the HANC – I don’t know about Arri Alexa unless it was added with the latest firmware.
    Michael
    Michael Phillips
  • Ben Schwartz
    August 6, 2011 at 2:20 am
    Right you are, sir. Thank you for that. Hopefully Alexa adds embedded HANC data soon.
