Activity Forums Adobe After Effects Using masks with particles
  • Using masks with particles
    Posted by Lou Williams on July 14, 2013 at 4:33 pm
    I created a mask in the shape of bottle and I am using the Cannon particle generator in AE to create the illusion of smoke like plasma within the bottle. All works well until the bottle is moved in the scene. Once the movement begins the particles start to fall outside the mask. I have the particle mask linked to the movement of the bottle and I can see the point generator following the movement but while it’s moving the particles are landing outside the mask. Once the bottle in the scene stops moving the particles seem to catch-up and are once again bounded by the mask. Not sure how to clean this up? Any suggestions would be helpful.
    Lou Williams replied 13 years, 2 months ago 2 Members · 2 Replies
  • Erik Waluska
    July 14, 2013 at 5:48 pm
    I’m not sure how you have this set up but I would suggest pre-composing your bottle with the particles and then just animating the position of the pre-comp.
    Erik Waluska
    EAWmedia.com
  • Lou Williams
    July 15, 2013 at 7:24 am
    Thanks — I will give that a try tonight
