Activity Forums Apple Final Cut Pro Legacy using mackie control surface with FCP
  • using mackie control surface with FCP
    Posted by Jong W. lee on January 29, 2008 at 2:17 am
    I’ve been trying to use MCU (Mackie Control Universal) with FCP, but no luck.
    Can anyone help me to set up this device for FCP (and Soundtrack pro too)?
    My (used) MCU came with MIDI/USB cable (midi1x1 by E-MU), so I hooked it up and select MCU under the ‘Control Surface’ in FCP… and even turned on the Audio Mixer window (Record audio Keyframe too.) That’s all i was able to do… What else should I do? Does it have to do to something with my Multibridge Pro or HDlink?
    Always appreciate your support
    Mac Pro 8-core 3.0Ghz, 8GB RAM, HDPRO4TB, Blackmagic Multibridge Pro, HDlink, Mackie Control Universal
    Andy Mees replied 18 years, 7 months ago 3 Members · 3 Replies
  • Jong W. lee
    January 29, 2008 at 6:48 am
    Actually I solved the problem… through the apple forum (final cut pro)
    So, anyone needs help on this topic, try apple forum
    you’ll find my post and ‘Andy Mees’ nicely detailed answer.
    thanks
  • Rennie Klymyk
    January 29, 2008 at 7:41 am
    I’m not sure if there are updates for fcp6 for this device. Here’s some info from the sound track manual for fcp5:
    https://www.mackie.com/Products/McuPro/PDF/SoundTrackProManual_pp243-246.pdf
    “everything is broken” ……1st. coined by Esther Philips I believe.
  • Andy Mees
    January 29, 2008 at 9:27 am
    issue resolved here
    basically mismatched control protocol settings between the MCU and FCP
