Activity Forums Adobe After Effects Using LUT files (lookup tables) in AE?
  • Using LUT files (lookup tables) in AE?
    Posted by Abraham Schneider on May 30, 2005 at 5:47 pm
    Hi!
    Is there any chance to use LUT files in AE? I have a custom LUT (normal text file) in Shake and would like to use the same file/information in AE.
    The only thing similar in AE seems to be the ‘Curves’ effect, but the .acv file which can be saved from this effect isn’t a normal text file.
    Anyone with an idea how to do this?
    Thanks for your help, Abraham
    Peter O’connell replied 21 years, 3 months ago 2 Members · 1 Reply
  • Peter O’connell
    June 1, 2005 at 10:58 pm
    You could try the cineon converter as an adjustment layer at the top or elin. That is, if you are using cineon files.
    Bye
    Pete
