Activity Forums Adobe After Effects Expressions Using loopIn and loopOut in the same expression
  • Using loopIn and loopOut in the same expression
    Posted by David Cabestany on July 20, 2022 at 4:50 pm
    Pretty much, what the title says, I’m trying to use one or the other via a conditional statement but I’m getting the following error:
    Undefined value used in expression (could be an out of range array subscript?)
    This is for time remapping a video, so add some head and tails to it.
    Thanks in advance for your help.
    n = 0;
    if (marker.numKeys > 0){
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time) n–;
    if
    (n<=1)
    {loopIn(“pingpong”)
    if
    (n>2)
    {loopOut(“pingpong”)
    David Cabestany replied 4 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 20, 2022 at 5:53 pm
    I’m not sure if this is what you’re after, but your expression needs to define what happens between markers 2 and 3.
    n = 0;
    if (marker.key(n).time > time) n--;
    if (n<=1){
    loopIn("pingpong");
    }else if (n>2){
    loopOut("pingpong");
    }else{
    value;
  • David Cabestany
    July 21, 2022 at 4:15 pm
    perfect, let me try it now.
    Thanks a lot Dan.
