Activity Forums Adobe After Effects Expressions Using linear expression twice in one layer
  • Using linear expression twice in one layer
    Posted by Danyl Bernard on December 22, 2020 at 9:43 pm
    Hi all,
    I have two linear expressions like this
    compLength = thisComp.duration;
    linear(time, inPoint, 1.2, [-1035.6667], [-2655.907]);
    linear(time, compLength + .2, compLength - 1, -2655.907, -7500);
    The first one changes the z parameter for the beginning of the comp, and the second one changes the end. But for some reason, only the second expression works.
    If I split them into two different layers and cut the layer midpoint in the comp, they both work fine. However, using them in the same comp doesn’t work.
    Also, how do I use a parameter like scale that has more than 1 parameter while using linear()
    Thank you
    Danyl Bernard replied 5 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 23, 2020 at 1:09 am
    Try it this way:
    if (time <= 1.2)
    linear(time, inPoint, 1.2, -1035.6667, -2655.907)
    else
    linear(time, compLength - 1, compLength + .2, -2655.907, -7500);
  • Danyl Bernard
    April 8, 2021 at 4:25 am
    It’s been a while, but this worked great.
    Thank you
