Activity Forums Adobe After Effects Expressions Using linear and smooth in the same expression
  • Using linear and smooth in the same expression
    Posted by Rod Duarte on November 18, 2016 at 5:03 pm
    Hi!
    So, this is what I’m trying to do.
    First, I followed Video Copilot’s tutorial on syncing an animation to audio. That provided me with this expression:
    linear(value,A,B,C,D)
    Where:
    A = lowest average value in your audio waveform graph
    B = highest average value in your audio waveform graph
    C = Value to use instead of A
    D = Value to use instead of B
    This worked. But the animation turns out quite harsh, so I wanted to smooth it out.
    Then I found this:
    smooth(2,5)
    Where:
    2 would be the number of seconds it’s looking at;
    And 5 is the number of frames the smoothing extends to.
    So I tried to do it this way:
    linear(value,2,30,60,100);
    smooth(0.5,19)
    It doesn’t work properly, because I’m trying to make a graphic in the composition, change scale with the music. It’s set to 60,100 in the first expression because I want the minimum size to be 60 and the maximum, 100.
    But when I add that smooth expression below it, the graphic shrinks, I can see in the scale parameter, that’s using little sizes like 1% instead of the 60-100 I want.
    What am I missing?
    Kun Chen replied 4 years ago 3 Members · 2 Replies
  • Dan Ebberts
    November 18, 2016 at 5:08 pm
    I’d say try it this way:
    s = smooth(0.5,19);
    linear(s,2,30,60,100);
    Dan
  • Kun Chen
    September 18, 2022 at 2:04 pm
    wow!!! thank you! it solved my problem!
