Activity Forums Adobe After Effects Expressions Using Layer numbers to set effect parameters. “name.split” Help
  • Using Layer numbers to set effect parameters. “name.split” Help
    Posted by Joe Wood on April 6, 2021 at 3:30 am
    Hello all,
    I am in need of some expression help using the name.split expression. I have tons of circles in individual shape layers that are all labeled “CD_01”, “CD_02” and so on. I’m connecting them all with beam effect to draw lines between them. Each beam layer is labeled “CL_01”, “CL_02”.
    I’d like it so the position expression of the beam effect updates each time I duplicate the layer, to follow the next numbered circle that matches the number on the beam layer’s name.
    This is where I’m at right now, but I’m getting a Sytex error
    n = thisComp.layer(“CL_01”).name.split(“_”)[1];
    CD = thisComp.layer(“CD_” + n);
    CD.position;
    Joe Wood replied 5 years, 4 months ago 1 Member · 1 Reply
  • Joe Wood
    April 6, 2021 at 12:58 pm
    Got it to work like this:
    var num = thisLayer.name.split("_")[1];
    var nam = thisComp.layer("CD_01").name.split("_")[0];
    var CD = thisComp.layer(nam +"_"+ num);
    CD.toComp(CD.anchorPoint);
