Activity Forums Adobe After Effects using launchpad to launch standard effects
  • using launchpad to launch standard effects
    Posted by Jason W. miltt on June 10, 2009 at 6:43 pm
    Since launchpad is dockable and always one click away I would like to use it to add levels, curves and other of the most used effects. The problem is that i dont know how to make them intro a script so that they appear in launchpad.
    anyone?
    Stuart Elith replied 17 years, 3 months ago 3 Members · 3 Replies
  • Jason W. miltt
    June 10, 2009 at 7:41 pm
    yeah but what about the nice little icons… 🙂
  • David Bogie
    June 10, 2009 at 7:49 pm
    You might talk to the launchpad developers but I’m having trouble seeing a practical application with AE. Easier to build a set of Favorites or Presets. Presets can even contain entire sequences of filters and keyframes.
    bogiesan
  • Stuart Elith
    June 11, 2009 at 1:37 am
    Hey Jason
    it’s not really what you’re after, but i found/made a script for applying an effect, which you can then assign to hotkeys using KeyEd (google it). So I have a few of my key effects assigned to hotkeys within AE, and it works really nicely.
    See this post :
    https://forums.creativecow.net/readpost/227/12690
    You’d need to paste that script into a script file (there are some already in the AE scripts folder, just copy and replace one). Then you go into AE and assign hotkeys in KeyEd Up to “Run script #…”.
    There’s a bit of fiddling involved, so if you’re actually going to do it, i will explain a bit further, but its a little messy.
