Activity › Forums › AJA Video Systems › Using KiPro to record DVD
  • Using KiPro to record DVD
    Posted by Michael Moser on January 28, 2010 at 7:38 pm
    Is there any reason why the KiPro can’t be used to convert the component or HDMI output of a non-restricted DVD from the component and/or HDMI output of a DVD player?
    Michael Moser
    Michael Moser replied 16 years, 8 months ago 3 Members · 6 Replies
  • Gary Adcock
    January 28, 2010 at 7:51 pm
    [Michael Moser] “Is there any reason why the KiPro can’t be used to convert the component or HDMI output of a non-restricted DVD from the component and/or HDMI output of a DVD player? “
    Recording of video from most consumer DVD players over HDMI is restricted by HDCP and the DRM security protocols- it is hard coded in the device and will not allow any discs to be recorded at all.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/garyadcock
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Michael Moser
    January 28, 2010 at 8:01 pm
    Have they also hard-coded this into component output of consumer DVD players?
    As there is no restriction on the disk, I thought there would be no problem.
    I’m trying to see if the up-convert I get is better than the software based system I usually use.
    I have an old Pioneer industrial DVD player which I’ll try this with also.
    -Mike
  • Gary Adcock
    January 28, 2010 at 9:28 pm
    [Michael Moser] “Have they also hard-coded this into component output of consumer DVD players? “
    Yes.the HDCP security is hard coded in the HDMI protocol.
    It is one of the specs required when you license the HDMI connectors and technology.
    gary adcock
    Studio37
    Chicago, IL
  • Michael Moser
    January 28, 2010 at 9:39 pm
    Yes, I understand the security is on the HDMI, but what about the three wire component output of the consumer units.
    Do they have a way of securing that as well?
  • Jeremy Garchow
    January 29, 2010 at 4:28 pm
    [Michael Moser] “but what about the three wire component output of the consumer units.
    Do they have a way of securing that as well?”
    If your DVD doesn’t have copy protection, you should be just fine. If not, you will have to go through a frame sync.
    Jeremy
  • Michael Moser
    January 29, 2010 at 10:59 pm
    It hasn’t worked coming out of the component ports…I’ll try a frame synch and report back.
    -m
