Activity › Forums › AJA Video Systems › Using Ki Pro below a Betacam
  • Using Ki Pro below a Betacam
    Posted by Michael Moser on December 14, 2009 at 11:28 pm
    I’m really pleased with the Ki Pro.
    One thing I discovered however (mentioned by Gary in a previous post, I believe) is that it should not be used under a Betacam or any other large camera if you want to have shake-free video.
    Generally for this use, I’m recording long-form events where I need to shoot from a distance.
    Because it raises the center of gravity, the heavy Betacam is more susceptible to shake when it’s mounted on the thin rail of the exoskeleton. I’ll experiment with some “low-mode” configuration; maybe it can be mounted above the camera, but common sense (and trying it once) dictates not to use the Betacam perched on top of the unit.
    Michael Moser
    Michael Moser replied 16 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
