Activity Forums Adobe After Effects Using Keylight for Luma Key? Luma Key effect “obsolete”?
  • Using Keylight for Luma Key? Luma Key effect “obsolete”?
    Posted by Scott Clements on February 20, 2015 at 12:46 am
    I am trying to luma key a human hand against black in After Effects. I initially tried using the luma key in Premiere and it worked great, but I was unable to add a mask. I am new to Premiere, so may be doing something wrong, but I just couldn’t implement a proper mask – the way I can in After Effects.
    So, I went to After Effects and tried to make a luma key using the luma key effect. No dice. No matter how I manipulated the key, it looked absolutely terrible – super crunchy – almost as though the footage was sot on DV or something – not what I expected at all.
    So, I found out that After Effects says the luma key effect is “obsolete” and suggests using the keylight effect instead. However, I’ve never known Keylight to be able to pull luma keys. I googled up on it and other people said the same thing.
    So, why is Adobe telling us to use keylight for luma keys? How do you pull a luma key in keylight? Any other methods?
    Film Editor, London UK
    http://www.scottclementseditor.com
    Steve Bentley replied 11 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Bentley
    February 20, 2015 at 1:15 am
    Instead of fighting with Luma key (especially with something shot on black) we’ll often just take a copy of the footage and crush it with a Levels filter and then either use a slight blur or use the matte choker to smooth it out a little. At least this way you can move the edge of the matte in and out and add as much anti aliasing to the edge as you like.
    Then take the original footage and use a luma track matte to pass it through this hi contrast “window”.
  • Walter Soyka
    February 20, 2015 at 1:54 am
    [Dave LaRonde] “You could try the Extract effect. That works pretty well.”
    This.
    Luma Key is considered obsolete because Extract does everything Luma Key did, and more.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Steve Bentley
    Forgot a step – make sure to apply a HSL filter and desaturate totally before running the levels filter on your matting elements.
    Good thought Dave – didn’t think of that myself – you can also use the matte choker with the extract filter to finesse the results.
    Another trick we will do is to “bipack” the original or some desaturated version of it. Just do a precomp with two copies of the original “multiplied” on top of each other. This will magnify the density of the non white areas. Then, in the outer comp pull your matte with any of the above suggestions. This of course depends on how white your white is.
    Dont hesitate to run a degrain or denoise before any of this. Yes it softens it but that’s not always a bad thing where mattes are concerned. But mostly is smooths things out before you start to crush the levels.
  • Matthew Wood
    February 20, 2015 at 8:10 am
    Well, so this is, generally, true, but not entirely. Luma still has options not available in extract
    Blood type O negative. I bleed zeros and ones
    I dabble on the desktop
    Shifted Leering, Any Perspective
    Shifting Literally All Perceptions
    SLAP
  • Scott Clements
    February 20, 2015 at 12:00 pm
    Thanks for all the information, guys!
  • Matthew Wood
    February 22, 2015 at 1:30 pm
    While maybe “very” uncommon, there are still times that can be handled better with Luma key, than extract. Without the need of adding another effect, that is.
    A black and white matte render that needs the alpha edges adjusted, is one.
    SLAP
  • Steve Bentley
    February 24, 2015 at 12:46 am
    Luma is still available in “obsolete” section of the effects list
