Activity Forums Adobe Premiere Pro Using keyframes to move text in Premiere CS5?
  • Using keyframes to move text in Premiere CS5?
    Posted by Dave Felder on November 2, 2010 at 7:41 pm
    Is it possible to move text by setting Keyframes in Premeire CS5? I’m trying to start with a keyed in title over footage, then have it move to the upper corner as a spokesman approaches the camera and begins to talk.
    I know I can do this with a transparent graphic made in Photoshop, but it would be more convenient to do in Premiere, if it’s possible.
    Dave Felder replied 15 years, 10 months ago 2 Members · 2 Replies
  • John Young
    November 2, 2010 at 9:32 pm
    Yes. Once the text is in the timeline. You will find the same MOTION controls in the Effect Controls panel that you would a graphic or really any element.
    http://www.johnathanyoung.com
  • Dave Felder
    November 2, 2010 at 11:24 pm
    Thanks John, I found it.
    I kept double clicking on the text clip in the timeline to put it in the source window, and as you know, that doesn’t work.
