Activity Forums Adobe Premiere Pro Using keyframes to MANUALLY stabilize a shot frame by frame is NOT WORKING PROPERLY?
  • Using keyframes to MANUALLY stabilize a shot frame by frame is NOT WORKING PROPERLY?
    Posted by David Notowitz on December 19, 2014 at 6:08 pm
    Dear Premiere Pro experts,
    Instead of using Warp Stabilizer, which for this particular clip, is not doing what I need, I want to manually stabilize the clip. I place a keyframe on each frame, adjust the position of that frame, and then move to the next frame and add the next keyframe.
    My positioning of the frames seems right, but if I go backwards a few frames in my sequence, and then move forward frame by frame, the frames which I thought I had correctly positioned just a few seconds ago are now not properly positioned.
    Can anyone help? I’m happy to share my screen with you online, and to get your input that way.
    What is going on?
    Thank you!
    David
    NCAVF, The National Center for Audio and Video Forensics
    https://www.NCAVF.com
    Ivan Myles replied 11 years, 8 months ago 3 Members · 2 Replies
  • Tim Kolb
    January 2, 2015 at 5:06 pm
    Can you check the keyframes to ensure all the interpolation is linear and that no auto-bezier or bezier interpolation has snuck in? Sometimes both PPro and After Effects make some absurd assumptions about how to interpolate keyframe paths unless they’re forced into linear.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Ivan Myles
    January 4, 2015 at 2:32 pm
    Also, if you have access to After Effects try using Motion Stabilization instead. I can speak from personal experience that manual frame-by-frame stabilization is extremely time consuming.
