Activity Forums Audio Using iZotope RX to level audio volume
  • Using iZotope RX to level audio volume
    Posted by David Notowitz on March 9, 2021 at 11:19 pm
    Dear friends,
    I have a recorded conversation between two people, where Person A is much farther from the mic than Person B, and I’d like to use something like the Leveler filter in iZotope to equalize the volumes to be at a similar level. The recording continues for over 3 hours.
    <font face=”inherit”>I was playing with Leveler, but this filter creates an audio ramp in </font>which<font face=”inherit”> we can hear the volume shift up and down between the </font>people<font face=”inherit”>, and instead I’d like a cliff. </font>
    Do you know the right current product, preferably in iZotope, but in Audition if necessary, to accomplish this?
    Thank you,
    David
    Chris Wright replied 5 years, 5 months ago 3 Members · 2 Replies
  • John Fishback
    March 10, 2021 at 5:29 am
    I use Waves Vocal Rider for leveling in Pro Tools. It has a slow and fast mode. I usually use slow, but fast might be better for your need. If there’s noise under the voices, try one of iZotope’s noise reduction modules. Dialog Isolate is very good. Hearing the noise go up & down makes the leveling more noticeable. Removing the noise might help.
  • Chris Wright
    March 10, 2021 at 4:21 pm
    I use this plugin. its crystal clear and doesn’t color the audio at all and its free! now obviously if you’re raising volume, you’re also going to raise the noise floor too, so you may need to use noise reduction.
    https://freevsts.com/loudmax/
