Activity Forums Apple Final Cut Pro Legacy Using iPhone video in existing fcp7 sequence with different frame rate
  • Using iPhone video in existing fcp7 sequence with different frame rate
    Posted by Jc Scruggs on February 1, 2014 at 6:49 pm
    I’d like to use iphone video in a sequence that has 7d video (23.98fps), prores422. I’ve tried converting the iphone video to prores422 but the playback looks choppy in the sequence. Can someone advise on the best way to convert the iphone video for a 7d sequence?
    Thanks, JC
    Lee Shallat chemel replied 12 years, 5 months ago 3 Members · 3 Replies
  • Shane Ross
    February 2, 2014 at 12:09 am
    The iPhone shoots 30fps…don’t even think it does 29.97, it does 30. Converting 30p to 24p will be choppy if you do it in FCP. Even with compressor it might be a little better, but not really smooth. For best options, use After Effects or premiere Pro
    Shane
    Little Frog Post
  • Jc Scruggs
    February 2, 2014 at 2:39 pm
    Thanks for the suggestions, Shane.
  • Lee Shallat chemel
    April 19, 2014 at 9:26 pm
    Used compressor to convert video from iPhone 4s to FCP 7 — Apple/formats/Apple Pro Res 422LT – Audio: passthrough – enabled
    Linear PCM/Steroe/48.00
    Yes to adjust settings
    Everything looks good, but I can’t use any video transitions or motion control
