Activity Forums Apple Final Cut Pro Legacy Using internal memory while exporting image sequence
  • Using internal memory while exporting image sequence
    Posted by Nick Avaliani on March 7, 2011 at 11:27 pm
    Hello
    I wonder if FCP uses internal memory when exporting rendered movie as image sequence? the movie is being exported to 6TB drive.
    What I need to do if it uses internal disk I want to change it so that FCP would use 6TB drive instead of internal memory. My export was interrupted several times and I think it was because of internal memory. So please can you recommend me how to change it to 6tb and so process will not be interrupted. I need files for DCP so I cannot continue from the number it was stopped. Sequence must be exported as one.
    Rafael Amador replied 15 years, 6 months ago 2 Members · 3 Replies
  • Rafael Amador
    March 8, 2011 at 2:36 am
    That’s not about internal/external HDs, but about virtual memory, caches, etc.
    I know that FC has problems on exporting long stills sequences from the time-line.
    Why don’t you export a self contained movie and try QT?
    rafael
    http://www.nagavideo.com
  • Nick Avaliani
    March 8, 2011 at 10:26 am
    I exported self contained movie so what I am doing next??? how can I export image sequence without FCP? and I must export uncompressed images 24 pfs.
  • Rafael Amador
    March 8, 2011 at 12:17 pm
    [nick avaliani] “I exported self contained movie so what I am doing next??? how can I export image sequence without FCP? and I must export uncompressed images 24 pfs.”
    Open in QT Player > Export > Image Sequence.
    Rafael
