Activity Forums Adobe After Effects Expressions using if else to set a variable
  • using if else to set a variable
    Posted by Adam Greenberg on October 19, 2022 at 2:16 pm
    Hi everyone, simple question I think,
    Is my 5th line of code correct ?
    I am trying to set this variable into a complicated expression, so I did not bother to paste the whole thing, only the problematic line.
    Basically I want ”a” to be a variable depending on which layer in the precomp is turned on;
    title=precomp1.source.layer(“title”);
    title2=precomp1.source.layer(“title 2 lines”);
    b=title.sourceRectAtTime();
    c=title2.sourceRectAtTime();
    if(comp(“precomp”).layer(“title”).active) var a = b else var a = c;
    Thanks so much
    Adam Greenberg replied 3 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 19, 2022 at 3:20 pm
    The JavaScript engine won’t accept if/else on a single line in that format. I’d do it like this:
    a = comp("precomp").layer("title").active ? b : c;
  • Adam Greenberg
    October 19, 2022 at 4:14 pm
    oh ok. Thanks so much Dan
