Activity Forums VEGAS Pro using gain on the audio track
  • using gain on the audio track
    Posted by Gary & yvonne on September 29, 2006 at 7:37 am
    How do you use the gain on the audio timeline…..i know you drag it down to change it but do you just usually leave it on the same setting all the time and just use the audio envelope to adjust sound? Thanks
    Edward Troxel replied 19 years, 11 months ago 2 Members · 1 Reply
  • Edward Troxel
    September 29, 2006 at 2:05 pm
    Yes. Use a Volume Envelope to adjust sound levels variably. If the entire track needs to be raised or lowered a set amount, then you can use the track level volume slider for that.
    Edward Troxel
    JETDV Scripts
